easy question about rendering??
how do you get rid of the blue planes when trying to use the acrobat distiller to render an image. also i cannot find the render button anywhere?? i cannot find the animate toolbar? and help? I am working in an assembly file.
thanks
thanks
RE: easy question about rendering??
To render: look under Environment, choose Virtual Studio.
For motion, choose Motion.
Pekelder
To render:
1) quick way is click on "shade" (a 3-D solid yellow box in menu)
2) more detailed is to click on Format View which brings up a view setup window where you can choose (eg) phong shading, or set up rendered faces using jpeg images, change perspective, etc. Then you can save as image or print to distiller. You can also change background to an image, gradient, solid, set up reflection boxes, lighting...
Not quite 3D Studio but good for quick images.
Hint: don't save as jpeg image. The image quality really degrades. Better to save as tiff and then convert to jpeg with another program if required.
