Saltwater Corrosion: Brass and 303 Stainless steel
I'm planning to use a thermostatic mixing valve with the following material specifications:
Valve body material: Brass with Type 303 stainless steel seat.
Valve trim materials: Type 303 stainless steel.
Will the valve materials get damaged with filtered and well oxigenated SALTWATER(34ppt) flowing through it at a constant rate and for a 5 months period?
Thanks a lot!
Thanks a lot!
