Anybody Using the New AutoCAD LT?
I was just curious if anyone was using the new AutoCAD LT. Is AutoCAD LT still set up where you cannot use AutoLisp or VBA? I wish they would create a version without 3D and with VBA or AutoLisp support that someone could afford.
RE: Anybody Using the New AutoCAD LT?
version of AutoCAD? Even if you only have R12 but
with the right customization, you can do a lot of
2D/3D drawings in the electrical field.
If you do program in VB and want some CAD capability that is not quite so expensive, you could look at VectorDraw. It is a component for VisuaBASIC that gives the programmer some control over CAD. The drawings can then be saved in DWG, DXF, or other formats.
I'm sure somoene else here can point you in the right direction, since I can't remember the names.
Sorry.....
try AutoCAD LT-Extender (Demoversion)...
http://www.lt-extender.com/englisch/frameset.htm
...and You can push up Your LT...
Lothar
Win NT4.0 (SP6),
ACAD 2000i (SP2), ADT 3.0 (SP3),
ACAD 2002, ADT 3.3,
OCÈ 5200
