Sticky notes on drawings
Is there a way to attach a "sticky" note to drawings that will appear on the drawing but will not plot? This is simlar to sticky notes used on PDF files. The only thing I have tried is putting notations on a different layer & then turning it off.
RE: Sticky notes on drawings
The closest thing that I know of is done by AutoView by Cimmmetry Systems http://www.cimmetry.com/cimweb.nsf. In addition to viewing and measuring SW files without SW, AutoView includes a redline markup feature. I have wanted to play with this but have never found the time to do so. Because of that, I don’t know that if the markup is actually visible inside SW or not.
Good luck
You are just jealous because the voices only talk to me.
I was not aware of that. I am still using SW2001+ which is probably the reason.
It really IS as bad as you think, and they ARE out to get you!
Sales wants us to have it so they can use it to wow customers, but they think it should come out of engineering's budget. Funny guys!
