I need information about specific feed water orifice plate EMCO
I have a water leak on this orifice plate  (for boilers)and I need information to know how to repair it, the brand of this feed water orifice plate is EMCO and the other data I could find is the number 327957 AZ. I was moving around internet without answers, if you could help me please let me now
Negro
RE: I need information about specific feed water orifice plate EMCO
What do you mean you have a leak in orifice? Is it orifice flange or orifice itself? If orifice is leaking than you need to replace it. You need to take it out measure the diameter and give it to machinist. Usually a paddle type orifice has a tab attached to it which has most of the information like dia, beta ratio, inlet etc. If you have that info give it to machinist and he will make you another one.
