Stamping
Stamping
I have a stamping project, the material that will be stamped out is a combination of Kevlar/fiberglass that has a thickness of .158" my current problem is that when material is stamped the cutter has to be cleaned each time because of material sticking to it. Questions are:
1) What would be the best steel to use for this cutter.
2) What should the clearance be.
3) Is there a plating operation available that could be done to Die set to help eliminate build up.
Cobb
Cobb
Scott Cobb
CSM Manufacturing, Inc
csm-mfg.com
RE: Stamping
Cobb
Scott Cobb
csm-mfg.com
RE: Stamping
Perhaps post this in Industrial/Mfg Engineering?
Pekelder
