Drain valves on LPG pipework
Does anybody have any experience of what type of drain valves are best to use on LPG lines, where the risk of water contamination exists ? We have used plug valves in the past, but they tend to jam up and sieze solid. A number of years ago we switched to ball valves, but the seats tend to wear and require replacing. The main problem is that the valve can freeze up when draining. This is particularly a problem after pressure testing when mositure can still be present in the line.
RE: Drain valves on LPG pipework
Might want to consider using a temporary threaded connection with a downstream globe or other valve so you still have the upstream root valve available to isolate the piping if needed.
