Air Lift Pump Design
I have a situation where it it agvantageous to have an air lift inclined at (Approximately) 60 degrees from horizontal.
The scenario is located in a wastewater clarifier, domestic sludge. In leu of cross bracing the tank, I was wondering how air lift pumps will perform at 30 degrees off vertical bracketed to the fillet. If anyone has experience, or guidance it will be appreciated.
Additionally, is air lift pump design guidance available?
Thanks in advance
Thanks in advance
RE: Air Lift Pump Design
Better to try before installing.
About deign tips ther is very little info avasilable.I have been using air lifts for several years and developed my own deign method(almost emppirical)
Hope this helps.
saxon
http://www.svce.ac.in/~msubbu/FM-WebBook/Unit-V/AirLift...
Send me an email and let me have your company name, email, location and fax and i'll send you a design methodolgy that was developed in the 1060's by DAVCO It is probably out of print. However, I'll be glad to get you a copy.
