CNC Swivel Head with High Speed Spindle
we are planning to retrofit our old Vertical Turn-Mill with Siemens 840D.  The mill spindle of this machine gives only 1000 RPM (max) and so we have a problem with cutting speeds (and feeds). We would like to replace this with a full CNC B-axis add-on to the spindle. This accessory is made by several companies. But this wont solve our problem of low cutting speeds. We would like to have a B-axis with electro-spindle.  Does anybody have such an accessory?
RE: CNC Swivel Head with High Speed Spindle
You may give this company a try, they seem to
be flexible on design and retrofitting...
Good luck
sorry, forgot to add the information!!!
Ryan Mathison
President
Specialty Design Engineering, Inc.
401 N. Lombard St.
Oxnard, CA  93030
Phone: 805-278-2633
Fax: 805-278-2654
www.sdecnc.com
