How to calculate pitch diameter of external threads
How do you calculate the minimum pitch diameter for external screw threads as listed in the machinists handbook table 3 in the threading section.
RE: How to calculate pitch diameter of external threads
Pitch dia.(max;min)=(1/2)( major dia.(max;min)-minor dia.(min;max). I just derived this last equation but you may want to carry it out with real numbers and see how it compares w/ your Machinist's Handbook. a
Perhaps the Unified threads use similar formulas. I would suggest trying to get hold of a copy of the ANSI standard.
Cobb
Scott Cobb
CSM Manufacturing, Inc
csm-mfg.com
