Eurocode & ENV Documents
Is there a source where I can find/download Eurocodes,especially ENV 1993-7 which deals with Marine and maritiem structures? As far as I know these European pre-standards are issued for experimental use and comment! Or, where can i find a CEN standards for the above?
Hope someone can help. Thanks.
Mark
Cape Town
RE: Eurocode & ENV Documents
Mark, I am not sure if this will help. But a while back when I was studying up on CE certification, they said all 'prestandards' as you call it, are published in a official CE periodical. The problem is, I can not remember the name of it. If I remember, I will check my links at home to see if I can come up with the name. I do know that all potential standards are published in this periodical before they are made mandatory. I believe it is a bi-annual periodical.
buzzp, thanx for your input. I have been doing somereading up and the ENV Documents (pre-standards) will be issued in the form of EN Codes sometime in 2003. However, it would be good to get hold of the current pre-standard env docs!! Especially thsoe for Eurocode 3 - Steel Structures, whic h contains 10 parts. Would be good if you can find those links at home. Thanks. Mark
I do not know about the particular EN you are looking for, but there are a number of places I get European standards from.  Try Global Engineering (global.ihs.com), www.nssn.org, and www.newapproach.org.
