Applying materials
Applying materials
Hello all!
When I want to apply material to a surface in Wireframe and surface Design, that particular material is not visible on the surface. How can I see that material?
Thanx in advance.
Thanx in advance.
RE: Applying materials
View > Render Style > Costumize View and activate materials option in window dialog.
Now if you make a click on
View > Apply Customized View, you mast see the material applied.
