Inclined orbit.
Inclined orbit.
If I receive an inclined satellite (satellite not stabilised) I have to use a tracking to maintain the position.
But during one day the linear polarisation change also.
I need have information about relation between polarisation modification and movement of the satellite.
Tks
Tks
RE: Inclined orbit.
This is effectively the polarization of the satellite and the antenna feed. It is difficult for ture tracking and optimized signal without a synchronized Polarization motor enable with your tracking system.
Or do you mean 'linear as in Az/el. If the satellite is orbiting, each consecutive path will be further west. A Geostationary is typicall a figure 8
Hope this helps
Iden
