Magnetism developed by austenitic 304 stainless steel after cold worki
Hi¡ everybody:
As we know, austenitic stainless steels show slight to severe magnetism depending on the amount of martensite transformation after cold working. However, I have not bibliography about it, Does any body have some literature to provide me.
One of my customers detected some magnetism on 304 ss (he produces storage tanks and, obviously, he had to roll the sheet), after the rolling operation he detected the magnetism. He is reluctant to believe that asutenitic ss becomes magnetic after forming operations.
RE: Magnetism developed by austenitic 304 stainless steel after cold worki
nick
Obviously you customer is not doing his home work. The subject covered in various shop and machinists handbooks.
Extensive cold working as well as extensive heat treating can produce a significant increase in magnetic attration especially in 304
If it has iron in it, it is hard to keep it from being magnetic
http://www.avestapolarit.com/upload/documents/technical/Cr-Ni.pdf
http://www.atlas-steels.com.au/PDFs/Tech/Cryomag.pdf
http://www.alleghenyludlum.com/pages/products/product.asp#
Then click on Technical Data Bluesheet
http://www.aksteel.com/pdf/markets_products/stainless/austenitic/304_304L_Data_Bulletin.pdf
The references that mcguire mentioned plus one additional book are available from ASM using the following links:
Metals Handbook Desk Edition, 2nd Edition
http://www.asminternational.org/Template.cfm?Section=BrowsebyTopic&template=Ecommerce/ProductDisplay.cfm&ProductID=11075
ASM SPECIALTY HANDBOOK Stainless Steels
http://www.asminternational.org/Template.cfm?Section=BrowsebyTopic&template=Ecommerce/ProductDisplay.cfm&ProductID=10524
Introduction to Stainless Steels
http://www.asminternational.org/Template.cfm?Section=BrowsebyTopic&template=Ecommerce/ProductDisplay.cfm&ProductID=10945
Peter Marshall: Austenitic Stainless Steels,
Kluwer Academic Publishers, Dordrecht Hardbound,
ISBN 0-85334-277-6
July 1984, 434 pp.
