Explain Data on ASME Form U-1
I'm seeking information on the minimum calculated shell thickness for a single chamber pressure vessel. Is this data provided on the manufacturer's U-1 or U-1A data report? There is a blank for Nom. Thickness under the shell section of the form. Is this the minimum calculated thickness for the given design conditions?
RE: Explain Data on ASME Form U-1
