Standard & Handbook about piping!!
Hi all
please tell me which standard is about piping?(ASME,BS,EN,...)
What is the best handbook for them?
tankx all
tankx all
RE: Standard & Handbook about piping!!
Thread378-12824
regards
Mogens
ASME is form Mechanicals, and also you could find some piping standard here, as, again, it deals with everything....
thanx 4 ur answers.
i think i need to explain my mean.
look.. for pressre vessels the megesy or moss handbook
r very usefull & all of the pressure vessel Eng. see them
i`m a beginner in piping & i like 2 know where i must begin!!
best regard
For what you need: You have the thick ASME, Section VIII, or the pedagogic, well structured german code, any up-to-date english version of the AD-Merkblätter, for pressure vessels. I would begin by this last one, and in somewhere, turn to ASME, Sc. VIII.
Good work
zzzo
for design use ANSI B31.x series piping codes, to do layout -ask senior piping designer or read "Plant piping design", to buy pipe according to the standard -use ASTM standards, to do piping hydraulic calc. - Crane had published very good manual, and so on. I am not sure if this answer will help.
thanx 4 ur answers . i think i foud the direction &
i found new friends.
best regard.
c u next.
Regards to Engineer Standards Practices:
www.pip.org
Civil/Structural/Architectural (C/S/A) CV, ST, AR
Coatings/Insulation/Refractory (CIR)CT, IN, RF
Electrical EL
Machinery RE (Rotating Equipment)
Piping & Instrument Diagrams (P & ID) PI
Piping PN
Process Control (PC) PC
Vessel VE
