How can I convert numeric to string?
Dear friends,
I want to calculate numeric (integer/float) to string. How couldI do that? Thanks
RE: How can I convert numeric to string?
Data Conversion
These routines convert data from one form to another. Generally these routines execute faster than conversions you might write. Each routine that begins with a to prefix is implemented as a function and as a macro. See Choosing Between Functions and Macros for information about choosing an implementation.
Data-Conversion Routines
Routine Use
abs
Find absolute value of integer
atof
Convert string to float
atoi, _atoi64
Convert string to int
atol
Convert string to long
_ecvt
Convert double to string of specified length
_fcvt
Convert double to string with specified number of digits following decimal point
_gcvt
Convert double number to string; store string in buffer
_itoa, _i64toa, _itow, _i64tow
Convert int to string
labs
Find absolute value of long integer
_ltoa, _ltow
Convert long to string
_mbbtombc
Convert 1-byte multibyte character to corresponding 2-byte multibyte character
_mbcjistojms
Convert Japan Industry Standard (JIS) character to Japan Microsoft (JMS) character
_mbcjmstojis
Convert JMS character to JIS character
_mbctohira
Convert multibyte character to 1-byte hiragana code
_mbctokata
Convert multibyte character to 1-byte katakana code
_mbctombb
Convert 2-byte multibyte character to corresponding 1-byte multibyte character
mbstowcs
Convert sequence of multibyte characters to corresponding sequence of wide characters
mbtowc
Convert multibyte character to corresponding wide character
strtod, wcstod
Convert string to double
strtol, wcstol
Convert string to long integer
strtoul, wcstoul
Convert string to unsigned long integer
strxfrm, wcsxfrm
Transform string into collated form based on locale-specific information
__toascii
Convert character to ASCII code
tolower, towlower, _mbctolower
Test character and convert to lowercase if currently uppercase
_tolower
Convert character to lowercase unconditionally
toupper, towupper, _mbctoupper
Test character and convert to uppercase if currently lowercase
_toupper
Convert character to uppercase unconditionally
_ultoa, _ultow
Convert unsigned long to string
wcstombs
Convert sequence of wide characters to corresponding sequence of multibyte characters
wctomb
Convert wide character to corresponding multibyte character
_wtoi
Convert wide-character string to int
_wtol
Convert wide-character string to long
std::stringstream ss ;
ss << scientific << 5.3*sin(1.23456) ;
cout "The answer is " << ss.str() << endl ;
Have a look at this article: http://gethelp.devx.com/techtips/cpp_pro/10min/2001/april/10min0401.asp
