Custom Drawing Borders
I have not received any training on the detailing of prints within Inventor. So, I am a bit lost when it comes to customizing the detailing environment. I want to pull in a custom company border, company mandated fonts, customized parts lists, etc... Is this easily accomplished within Inventor, or do I need some helpful advise from those who have already gone down this typical path. Thank you
RE: Custom Drawing Borders
some things to look at:
Format Menu > Standards
Format>Dimension Styles
that's where you'll set up the "style" of your sheet.
also, in the browser under a folder called "Drawing Resources", right click on Titleblock to define new titleblock, same for borders etc...
just play and you'll figure it out pretty quick.
it's all fairly straight forward as i said...
good luck.
