Thickness of various Cu weight on PCBs
Does anyone know what the thickness of the Cu is for various weights of Cu plating used in PCB manufacture? ie:0.5oz, 1oz and 2oz copper
RE: Thickness of various Cu weight on PCBs
Have you tried to contact a supplier?
TTFN
One ounce copper means that one square foot of a given thickness of copper will weigh one ounce.  Now if you look up the volumetric weight of copper and work backwards, you will find that one ounce of copper in a sheet one foot square is about 0.00135 inches thick.
The proof is left to the student.
Check the webside of Rogers.
Thanks for your help everyone.
For anyone else who wants to know: (per Rogers Corp. website)
0.5oz Cu = 0.7 mil
1oz Cu = 1.4 mil
2oz Cu = 2.8 mil
For the people prefering SI-units:
0,5 oz: 17um
1 oz:   35um (most common)
2 oz:   70um
3 oz:  105um
