Nitrogen Purity - Is 98 % too low?
We are a batch chemical facility and purge and blanket with nitrogen. The nitrogen is generated with a nitorgen generator putting out a 99.5% purity with liquid nitrogen backup. Has anyone out there ventured to use a lower purity -say 98 % nitrogen.. We have a couple of proudcts that chemically will degrade so we will bring pure nitrogen to these tanks but we are looking at the safety aspects and it scares a lot of people to lower the purity.
RE: Nitrogen Purity - Is 98 % too low?
What is your concern? Do you want to increase the capacity of plant by reducing purity?
Generally there should not be any problem upto 7.5% oxygen (as far as ignition problems are concerned) But for oxidation, well it is your judgement.
Is it a PSA Nitrogen Generator?
It depends on your application.
If your N2 is coming off a PSA, then check flow very carefully. My experience with PSA (pressure swing absorption) units is that the rating of 98% N2 will be at a specific flowrate. As the flow goes up, the purity goes down.
