Importing XYZ Coordinates Into SolidWorks
Hi
Does anyone know how to import points in XYZ format into Solid Works?
I am trying to generate a solid model of a transition duct using points, splines and the like. Currently my data is XYZ format in Excel.
Thanks!
-S
RE: Importing XYZ Coordinates Into SolidWorks
Start a new part and select form, the pull down menu, curve, curve through free points.
BBJT CSWP
Sorry that should read
Start a new part and select from, the pull down menu, curve, curve through free points.
BBJT CSWP
'copy and run this macro
'MAKE SURE OF THE FOLLOWING:
'all automatic contraints are OFF
'Zoom in to a very small area in your model in order to prevent merging of points
'source file is text file named "3dpoints.txt" in same directory as macro
'each line is a point coordinate in the format x    y    z[return] (you can save this from excel file
' 3DPoints.swb      8/3/99
' Edit a 3D sketch and run this macro to automate the creation of 3d points.
' Point data is in a TAB delimited file "3dpoints.txt"
' ex:   1.0 2.1 1
'       1.2 2.0 -1
' Macro written by Joe Jones    joe@nhcad.com
' New Hampshire CAD             www.nhcad.com
' MECHANICAL DESIGN & CUSTOM PROGRAMMING
Dim swApp As Object
Dim modelDoc As Object
Dim retval As Object
Dim dataStr As String
Dim I As Integer
Dim Coords(1 To 3) As String
Dim Cnt As Integer
Dim Units As Integer
Dim Conversion As Double
Sub main()
    Set swApp = CreateObject("SldWorks.Application")
    Set modelDoc = swApp.ActiveDoc
    ' calculate conversion factor for meters --> current units
    Units = modelDoc.LengthUnit
    Select Case Units
    Case 0 ' mm
        Conversion = 1 / 1000
    Case 1 ' cm
    Case 2 ' m
        Conversion = 1
    Case 3  ' in
        Conversion = 1 / 39.37
    Case 4, 5 ' ft and ft-in
        Conversion = 1 / 3.28
    End Select
    ' read data file
    Open "3dpoints.txt" For Input As #1
    Do While Not EOF(1)
        Cnt = 1
        Coords(1) = ""
        Coords(2) = ""
        Coords(3) = ""
        Line Input #1, dataStr
        For I = 1 To Len(dataStr)
            If Mid(dataStr, I, 1) = Chr(9) Then
                Cnt = Cnt + 1
            Else
                Coords(Cnt) = Coords(Cnt) + Mid(dataStr, I, 1)
            End If
        Next I
        Set retval = modelDoc.CreatePoint2(Val(Coords(1)) * Conversion, Val(Coords(2)) * Conversion, Val(Coords(3)) * Conversion)
    Loop
End Sub
On justice and on friendship, there is no price, but there are established credit limits.
oops the TGML messed up one of my notes:
format for coordinates is x[tab]y[tab]z[return]
source code derived from code downloaded from NHCad.com
Thank You Very Much!
This will hopefully alleviate one of my headaches with creating this geometry.
-S
