Model of drawing in rollback state
When I switch from a model to a drawing, I get a message that the model is in rollback state, and that the drawing is inaccessible. The part is not in rollback state. I can do nothing in the drawing. I cannot delete the views. I cannot even load the model from the browser!
My part has multiple configurations, and a design table, and I have just done significant changes to it. I do not remember how I caused this last time.
This has happened several times to me. Is anyone familiar with this? Does anyone know what do do?
JHG
JHG
RE: Model of drawing in rollback state
Perhaps one of the configs you weren't referencing was in rollback mode?
Mr. Pickles
Regg
SolidWorks eventually crashed. When I re-opened, everything came up okay.
The problem is, my part is not rolled back, my drawing insists that it is rolled back and cuts off access to everything, including the kill button. I need the task manager to shut things down -- or a crash.
JHG
Regg
>> After your system crashed and you restarted, the drawing opened without giving you the rolled back message. Is this correct?
Yes.
JHG
Regg
I have seen the same thing and have never been able to isolate it or duplicate it. It simply doesn’t happen often enough for that. I do have a suspicion though.
There are times, when I open a drawing first that SW will tell me that the drawing and model are out of sync and needs to be updated. Normally, I ignore this and open the model thinking that it will update the drawing. Most of the time it does, but sometimes it doesn’t and you have to specifically tell the drawing to update itself with a Ctrl-B or a Ctrl-Q.
The trouble with life is that there is no background music! I want that music!
