master on science vs master in engineering
Hi
I'm finishing my undergraduate studies in the aeronautical engineering field. And I decided to continue my education with a master's degree. But I have to choose between two kind of masters: Master of science in aeronautical engineering (aerodynamic field) or the master of aerospace engineering (M.eng). I understand the difference in the curriculum and requirements for both degrees.
I'm wondering, however, does the professional world see the two degrees as equal or different when employer's are seeking someone with a master's degree? Would one degree be considered better than the other? When would one be preferred over the other and why?
RE: master on science vs master in engineering
The importance of either degree to a potential employer tends to be rather subjective - I work in a large UK aerospace organisation and there tends to be a lot of debate here amongst managers over the relative importance of the various levels of higher education (never mind distinguishing between various specialities at the same level!) Every employer will have their own preference as to which is best. From a purely human nature perspective, an MSc does tend to be the better known qualification as there are a lot more of them around but, equally, most managers in my experience would see the Master part of the qualification as being he important bit.
Basically, there is no right or wrong decision regarding choosing between an MEng and an MSc, all other things being equal. The important thing is to choose the option that is right for you.
Incidently, I've got both an MSc and an MEng and have never noticed any real preference for one over the other when dealing with employers - while qualifications help get your foot in the door, your working abilities and inter-personal skills are what keep you moving in your career.
Don't know if this is any help,
Rikman
thank you very much for your advices.. that s what i was expecting...
I really apretiate it ...
thank you again
