Virtual I/O board
Virtual I/O board
I am doing a project which requires using 2 existing softwares:
+ Software A was written to produce 3 analog outputs and it supports the analog output board ACL 6126.
+ Software B was written to receive the 3 analog outputs produced by software A and analyse them. It supports the card DT9800.
Obviously, the 2 softwares can be installed in the same PC.
Is there a way to feed the outputs of software A to software B without actually using the I/O boards?
A restriction is that I am not allowed to do any modification on software A.
Thanks ;)
Thanks ;)
RE: Virtual I/O board
TTFN
