Partition/Mesh
Partition/Mesh
Partition/Mesh
hey.
I have imported a shell part from SolidWorks to ABAQUS 6.3.1 CAE. In the process of making a valid and precise part i have deleted/created many faces. This has resulted in many partitioned edges wich leads to nodes on these points when i mesh the part.
Are there any possibilities to make  the mesh generator ignore these partitiones on the edges in order to simplifye the mesh?
(Deleting the partitions makes regenerating the faces impossible)
RE: Partition/Mesh
You can remove unwanted/redundant vertices in the part module, near to the repair tool, otherwise the mesh generator cannot ignore partitions.
