Pavement "Crack and Seat" Technique
The crack and seat technique is a pavement recycling method where the existing PCC pavement is cracked and seated in place before constructing an asphalt overlay on top; it's normally done to minimize reflective cracking in the asphalt. Does anyone know if this method would work where the existing PCC pavement is reinforced? Thanks.
RE: Pavement "Crack and Seat" Technique
If you intend to use this method in a residential area, you would do well to document the pre-existing foundation and wall cracks, inside and out, swimming pool cracks, etc., as you are sure to own every one when the project is complete.
