Divide Part and Saved hole settings
V11SP8 When I divide a part and create 2 new ones,there are no favorite hole settings in the new part file.It's as if it uses a different template file.Any one know a way around this?
RE: Divide Part and Saved hole settings
In later releases, the parent template is used to create the children. For v11, your best bet would be to verify what template was used and modify that template to include your hole settings.
I figured it was using a template,but it must be hidden ,'cause I have my hole settings on all the templates.(renamed mine normal.par etc.
