Siphon pipe-- maintain empty or full?
Should a siphon be maintained full or empty when not in use? I'm designing an 8" diameter, ductile iron siphon to be used on a small fresh-water reservoir. It will only be operated once a year. It will have a valve at both the inlet and outlet ends. Aside from priming considerations, should the siphon be kept full or drained empty after use? Which would result in less corrosion of the pipe?
RE: Siphon pipe-- maintain empty or full?
Having said that, I see 2 options:
1) completely drain and blow out all the water with dry compressed air before closing the valves, or
2) leave filled with water, but add some TSP (trisodium phosphate) as a corrosion inhibitor and use some lime to boost the pH to 10-11 (minimize the solubility of iron). Add via the priming system so as to not leave any air in the system.
Please note that this is just for my information and knowledge.
Don’t worry about the the small amount of dissolved oxygen. It may help with formation of a passive layer.
The point of raising the pH is to increase the stability of iron hydroxide vis-à-vis dissolved iron. See Thread127-52975. This way, you have a stable, thin film of FeOOH on the surface rather than iron dissolving as Fe+3. Additionally, the TSP should create some iron phosphate protective film.
Incidentally, should you decide to drain the tube, it would be a good idea to first treat the water inside (raise the pH and add the TSP) to leave a protective film.
quark,
In this case (ductile cast iron), the carbon (graphite) is a primary phase. You could still get intergranular corrosion between the ferrite and graphite grains. And, since the graphite is very cathodic to the ferrite, it would be of galvanic nature.
"The strength, durability, and long service life of Ductile's predecessor, gray Cast Iron pipe, are widely recognized. The first official record of Cast Iron pipe installation was in 1455 in Siegerland, Germany. In 1664, French King Louis XIV ordered the construction of a Cast Iron pipe main extending 15 miles from a pumping station at Marly-on-Seine to Versailles to supply water to the fountains and town. This pipe served the palace gardens for more than 330 years.
Cast Iron pipe was introduced to the United States as early as 1817, when it was installed in the Philadelphia water system. Today, more than 565 utilities (in the United States and Canada) have had Cast Iron mains in continuous service for more than 100 years. Additionally, at least 16 utilities have had Cast Iron mains in continuous service for more than 150 years.
Ductile Iron not only retains all of Cast Iron's attractive qualities, such as machinability and corrosion resistance, but also provides additional strength, toughness, and ductility. Although its chemical properties are similar to those of Cast Iron, Ductile Iron incorporates significant casting refinements, additional metallurgical processes, and superior quality control."
Point being, just put in ductile iron and forget about it. The corrosion will not be a problem in our lifetimes.
Corrosion should not be a big problem as you can internally lined the ductile iron pipe with concrete lining, epoxy or bitumen coating.
As your pipe will be operated once a year, another point you have to be awared of, if you choose to have a filled pipe, is water trapped inside the pipe will become septic. Make sure you can drain this water away from your system before operation.
BobPE
