Balancing service?
Balancing service?
Anyone know where I could get a 12.75" dia. X .09" thick disk dynamically balanced up to 6000 rpm? The disk has a thru slot and a set of 'counter balance holes' opposite the slot but on a different 'bolt circle. All holes are through. The cad system shows that the theoretical center of mass and center of rotation are the same. Taking into account machining tolerances and consistant material density, I need a backup plan should these disk's (there are 3) need balancing. Two counter rotate on a common 6mm shaft 1/8" apart although I would prefer to balance the disks separately.
RE: Balancing service?
What you are asking for could be hard to do. A dynamic balance involves 2 or more correction planes ........ with 0.090" plane seperation, this is a tall order. Also, un balance does increase as a square of the speed, but at 6,000 RPM your part mounted on an arbor may become flexiable, (depending on balance machine bearing span, and other factors),not to mention mounting concerns with the loads that go along with that speed. At any rate, I do know of a place, if you are still looking, you can email me
rrasdave
Good luck
Ralph
Talk to Unversal Balancing in Bristol if you're in the UK. They're ace.
http://www.1stdirectory.com/cd.asp_Q_DId_E_19_A_CId_E_51407
will give you the email
Excessive accuaracy is a sign of poor breeding. -Socrates.
Of course, CAN and WILL are different things.
