Cavitation Temperatures
Can anyone offer leads or specific information regarding the observed temperature of cavitation implosions? My primary concerns are in the 20 thru 2,000 psi pressure range but any information will be helpful.
RE: Cavitation Temperatures
I think we need a little more information.
What fluid are you refering to?
Are you talking about the heat generated by the implosion itself?
Please give us a little more info.
Quoting from Karasik and others' Pump Handbook (McGraw-Hill) page 2.214:  "Controlled experiments with water indicated that the damage to metal depends on the liquid temperature and was a maximum at about 100 to 120oF (38to 49oC." The whole chapter deals with cavitation and it is enlightening in many respects.
Yes, Gregcase, I refer to the heat generated by the implosion itself. Fluids of primary concern are water(tap & sea)and petroleum oils.
