Where Can i buy a tunable Dye Laser?
I neeed help to find three diferent colored dye lasers for a experiment about which wavelengths travel farthest through water, also if anyone could tell me where to purchase a collector so that I could measure the decrease in energy through the experiment. Thank you I would greatly appreciate any advice.
RE: Where Can i buy a tunable Dye Laser?
Have you done a websearch for dye lasers?
By collector, I assume that you're referring to a "detector". There are a number of suppliers with websites. What path length you use will dictate the type of detector and the degree of difficulty. Have you considered how you intend to calibrate all this stuff?
TTFN
thank you
I am VERY new to lasers and do mean detector, and i have found suitable lasers but am still searching for a Detector, if you have any companies that you could point out i would be very grateful.
thanks again.
There is also some question as to the validity of using a laser, since the scattering coefficient for water is extremely high. This means that probably 99% of the transmitted energy will not reach any detector you could possibly configure; is that allowed?
Transmission is a very non-trivial measurement and you should get someone a little more knowledgeable to ensure that you're doing it right and doing the right thing in general.
TTFN
Thanks again, i will try to find someone thank you though.
A commercial tunable laser is probably well beyond the budget for this type of project. I'd suggest borrowing a fiber-optic light source with around 200W capability. Use commercial color or band-pass filters:
http://www.edmundoptics.com/IOD/DisplayProduct.cfm?productid=1924
http://www.anchoroptical.com/Products/Display.cfm?catid=266
TTFN
TTFN
