SolidWorks Doc props: from API?
This one *seems* easy enough: there are properties available
to link to drawings and models, even when 'manually' making parts, that are not listed in the standard File Properties tabs of "Summary", "Custom", or "Configuration Specific", but are available in a design table as properties, such
as "$PARTNUMBER" and "$PARENT".
Anyone know of a way to access these variables thru the API,
if a Design Table is not present?
RE: SolidWorks Doc props: from API?
For $PARTNUMBER see Configuration::UseAlternateNameInBOM
and Configuration::AlternateName
As for $PARENT, I am not familar with that.  If you could give an example, it may wake up my brain.
Regg
This code is from Joe Jones at:
http://www.nhcad.com/old/html/example7.html
Example 7 - config props.swb
' Config Props.swb
' Joe Jones
' New Hampshire CAD www.nhcad.com
' 03/09/98
' Will write several custom properties to active configuration
Dim swApp As Object
Dim Part As Object
Dim Configuration As Object
Dim ConfigName As String
Dim retval As Boolean
Sub main()
    Set swApp = CreateObject ("SldWorks.Application")
    Set Part = swApp.ActiveDoc
    Set configuration = Part.GetActiveConfiguration
    ConfigName = configuration.Name
    ' retval is True or False upon successful AddCustomInfo3 function
    retval = Part.DeleteCustomInfo2 (ConfigName, "drawnby")
    retval = Part.AddCustomInfo3 (ConfigName, "drawnby", _
        30, "Joe Jones")
    ' will insert todays date
    retval = Part.DeleteCustomInfo2 (ConfigName, "Date")
    retval = Part.AddCustomInfo3 (ConfigName, "Date", 64, Str(Date))
    retval = Part.DeleteCustomInfo2 (ConfigName, "LuckyNumber")
    retval = Part.AddCustomInfo3 (ConfigName, "LuckyNumber", _
        3, 345.99)
    retval = Part.DeleteCustomInfo2 (ConfigName, "Success")
    retval = Part.AddCustomInfo3 (ConfigName, "Success", 11, "Yes")
End Sub
Bradley
