Title Block creation??? Can anyone help?
I am trying to create a brand new title block for all US customary sizes (A,B,C,D & E). I have used the help menu and it says to go to INSERT then LAYOUT then CREATE LAYOUT WIZARD. I went through these steps and I do not want to create a layout, but I do want to create my own Title Block that is specific to our company. Can anyone lead me through this process.
Thanks in advance,
Brent Wood
Process Engineer
PEN Products
Thanks in advance,
Brent Wood
Process Engineer
PEN Products
RE: Title Block creation??? Can anyone help?
1. Start a new drawing
2. Draw the title block 1:1
3. Insert default text for drawing name, drawn by ...
4. Configure standard formats for text
5. Insert all standard notes (tolerance ...)
6. Assign attributes to the text such as Drawn By, Date,
Drawing Name, etc. For example, call the drawn by text
'DrawnBy'
7. WBLOCK the entities and set the insertion point to 0,0
Then, when you want to make a new drawing, you insert the BLOCK into your drawing at the current drawing scale. If you type DATTE and select the block, you will be prompted for the title block data that you setup with attributes. This beats inserting text and prevents you from exploding the block.
I am sure that there are hundreds of ways to accomplish this, but we have written programs that utilize this format to automate our product design.
DimensionalSolutions@Core.com
While I welcome e-mail messages, please post all thread activity in these forums for the benefit of all members.
Hope this helps!
Steve Smith
Product Engineer
Staco Energy Products Co.
www.stacoenergy.com
Tommy
Brent Wood
Process Engineer
Let me know your e-mail address so that I can send you a zipped file with the menu addition & a readme text file.
By the way I agree with TWong in that all your title blocks
should have all the same info. Ours are all the exactly the same, including size.
Steve Smith
Product Engineer
www.stacoenergy.com
I would appreciate if you would e-mail me your menu to the following address: brianmg@cork.mcos.ie
Thanks in advance for your help. Keep up the good work with all the tips you provide - they are very helpful.
I would definitely like a copy of the program that automatically inserts title blocks from the main menu. Thank you in advance! I hope that I can be of help in the near future!
Brent Wood
Process Engineer
PEN Products
If you don't want to display it here, e-mail your address to my Yahoo address steveasmith2000@yahoo.com.
Steve Smith
Product Engineer
www.stacoenergy.com
