Sulphate resistance concrete
Hi all,
My contractor is proposing a high silica compound with type I cement as the screeding of an oxidation pond( no lining) instead of type V cement. My friend recommends a High alluminate compound to mix with type I cement instead. My previous experience was applying a bituminous coat on a normal portland cement concrete mix. I'm not familiar with the requirements of chemical resistance for concrete structures holding non industrial sewage. Type V cement seems to be the obvious choice. If I'm stuck with Type 1 cement, what's the best way out?
Longisland
Longisland
RE: Sulphate resistance concrete
Be careful with high silica mixes. Unless carefully controlled, you might get additional shrinkage cracking. In a structure such as this, minimizing cracks is certainly a goal!
