Flotran: Estimating Drag Coefficient of a Rocket
Im new to Ansys and to the subject of CFD. I waould appreciate any help in a problem im trying to solve in Ansys, which is a small part of my final year project dealing with the design of a small rocket.
I want to perform a simulation of the rocket in flight in air uptil 2500m above MSL, SOLELY for the purpose of estimating the Drag coefficient of the entire rocket (contributed by Nose, Body & Fin interference). I know the the following should be the input parameters:
Nose Cone
- Length
- Diameter
- Profile/Shape
Body/Fuselage (Without Transitions)
- Lenght
- Diameter
- Surface Roughness Height
Fins
- No. of Fins
- Length of Fin Sides(4)
- Fin Thickness
- Thickness at Front Edge
- Profile
Launch Lugs
- No. of Lugs
- Height, Width, Length, Thickness
Other Conditions
- Lower & Upper Mach nos
- Altitude
TO DETERMINE Cd of
Entire Rocket
Body Skin Friction
Nose Pressure Drag
Base Drag
Body Pressure Drag
Fin Pressure Drag
Interference Drag
Fin Skin Friction
I hope to receive your kind help.
Thanx.
Aristo
Nose Cone
- Length
- Diameter
- Profile/Shape
- Lenght
- Diameter
Fins
- No. of Fins
- Fin Thickness
- Profile
Launch Lugs
- No. of Lugs
Other Conditions
- Altitude
TO DETERMINE Cd of
Entire Rocket
Body Skin Friction
Nose Pressure Drag
Base Drag
Body Pressure Drag
Fin Pressure Drag
Interference Drag
Fin Skin Friction
Thanx.
Aristo
