Fatal error in drawing start up ?????
My problem :
Yesterday i finished my day quick-saving my file in mdt4. Suddenly this morning i couldn't open it. I can open other files with out having any problem.
It has given me two openings.
1. Exception in acme.arx ARX COMMAND
Unhandled exception c0000005 (access violation reading 0x0000) at adress 56557623h.
I accept ok and my file show up with out the desktop browser. When i try to display the browser it show me:
Exception in C:\mdt4\desktop\mcadcom.arx ARX COMMAND
Unhandled exception c0000005 (access violation reading 0x0020) at adress 528110b0h.
And when i accept ok the is written in the command line "ADS request error" and i find my self back looking at my drawing, but i can't do anything in it.
2. (second opening)
AutoCad error aborting
Fatal error: Unhandled access violation reading 0x0240 exception at 52805544h.
I accept ok and...
AutoCad error-abort
Error handler re-entered. Exiting now.
Thereby the complete software program close and i can start all over if i'm in the mood.........
When i having the first opening the F2 tab show me this :
Loading arx file : acme.arx
Loading Modeler DLLs.
Loading arx file : amdt_attributes.arx
Loading arx file : grefacad.arx
Loading arx file : cit.arx
Loading arx file : mcadcom.arx
Loading arx file : dm.arx
Loading arx file : asrf.arx
Loading arx file : ad.arx
Loading arx file : grefad.arx
Loading arx file : assembly.arx
Loading arx file : mcadapi.arx
Loading arx file : mapiad.arx
Loading arx file : grefsurf.arx
Loading arx file : grefam.arx
Loading arx file : grefdm.arx
Loading arx file : grefsys.arx
Loading arx file : ge_load.arx
Loading arx file : acmsymbb.arx
Loading arx file : amg3.arx
Loader application completed
Opening an AutoCAD 2000 format file.
Resolve Xref "NK_1_55": C:\Schneeberger downloads\NK_1_55.dwg
"NK_1_55" loaded.
Resolve Xref "NK_1_35": C:\Schneeberger downloads\NK_1_35.dwg
"NK_1_35" loaded.
Regenerating model.
I hope anybody have solved such a problem before or just know how to do it.
Thank you very much.
2. (second opening)
I accept ok and...
AutoCad error-abort
"NK_1_55" loaded.
"NK_1_35" loaded.
Regenerating model.
RE: Fatal error in drawing start up ?????
Try loading MDT and typing 'recover'. Hunt your file and let MDT try and fix it.
Or revert to the autosave drg auto.sv$ by renaming it with a *.dwg extension.
I am not an active ACad user but found useful information to a similar problem at
http://www.fredrick.com/technicalsupport/acaddocs/td115345.html
Good luck!
Good Luck.
Matt
MDT5 user
