Importing DXF/DWG to sheet formats
Hi - I am running 2003 and am trying to import either dxf or dwg files.  I want to set them up as sheet formats and they keep getting imported as blocks.  I have tried the help and am getting nowhere.  Any suggestions? Thanks
RE: Importing DXF/DWG to sheet formats
Once you have the block, you can explode it.  Then you can cut and paste into the format.
Gravity is a harsh mistress.
