Acad 2000i & winXP - Open dialog box view
When I hit "open" in Acad 2000i running in XP, it always shows the files in icon view, instead of in list or detail view. I've changed the folder view option in XP, but it doesn't affect AutoCad. How can I fix this?
Thanks!
Thanks!
RE: Acad 2000i & winXP - Open dialog box view
FYI Autocad LT2004 on WinXP doesn't have this problem.
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R15.0\ACAD-1:409\Profiles\"username"\Dialogs\Select File
Set the value for ViewMode to "3" for list and "4" for details.
After doing this for a while, ACAD seems to rewrite the registry value to "1", changing the view back to icon view. Is there some way to lock a registry value?
