Inspection Dimensions in Solidworks
Does anyone know where the Oval originates from on an Inspection Dimension in Solidworks?
The Oval doesn't exist in any ANSI or AMSE book that I can find or anyone I have talked with about this. I have went back to 1988 ANSI and nothing...Maybe I'm missing something here, but I can't seem to find an answer for this.
Anyone have an Idea?
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
When in doubt, always check the help
RE: Inspection Dimensions in Solidworks
I think the "inspection dimension" bubble in SW is actually derived from a DIN standard, but I don't know the number.
Ray Reynolds
Senior Designer
Read: FAQ731-376
"Probable impossibilities are to be preferred to improbable possibilities."
Here is what I finally found out.
The reason SW has the ovals around the inspection dimensions is because a long time ago a large company wanted those ovals there and it just stayed there. The company was of course buying SW at the time.
It isn't an ANSI standard that I know of or any standard that I'm aware of. Maybe a distant form of a DIN standard. That supports this option.
Scott Baugh, CSWP
FAQ731-376
Scott, my interpretation, especially working wit MD, is that ovals are actually mirrored ellipses. .  When I spec. its always major/minor axis with a c/l.  This works for my job but not the standard your looking for.  I give the little gray cells a chance to work on it.
