Creating a Block and adding linked properties to it
Ok....basically I need to be able to take a standard blocked out sheet that I have in autocad (same exact fonts and everything), and put it into a workable solidworks template. Ive been messing with this for a day now and it's driving me mad. I DID read the help file first, but unfortunately it wasnt very descriptive in this case. I want something where I can control scale and all that (just like the preset templates that you get when you first buy solidworks). If anyone can give me some advice, I'd really appreciate it!
Jay
Jay
RE: Creating a Block and adding linked properties to it
Or
You can save it as a template and when you click New it will be available to pick from the New menu box.
IHTH,
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
When in doubt, always check the help
The note or block is controlled by the property, but the property can not be changed through the note.
One more thing I noticed about properties in notes used in blocks: the notes don't always update immediately after changes, but the updates do appear after rebuild. This is especially true with the "last saved date" proprerties.
