Upside down dimensions in sheet files
When I place a dimension in a reference file then I view it in the sheet file, the dimension comes in upside down.  If I drop the dimension, it comes in fine.  I would prefer if possible not to drom the dimension.  The view in the reference file is rotated.  Does anyone know if there is an easy solution or do I have to drop the dimension?
RE: Upside down dimensions in sheet files
Have you tried placing the dimension in your sheet file?
Under the pull down for ELEMENT>DIMENSION>PLACEMENT ...
Check the box that says "Reference File Units".
The "DIM" should scale to your reference file.
Hope that helps.
Placing the dimension on the sheet file does work will, but I would prefer to dimension directly in the reference file.  I guess I tend to move the reference files around a lot especially when I have multiple details.  If I were to dimension on the sheet it would just take more time.  Thanks rkey
rich
I found the answer to my question, just want to share it with everyone.
If you place a fence around the dimensions and key in: FENCE FREEZE the dimensions will act as though they have been dropped and the dimesions will come in as intended.  If later you want to manipulate the dimensions you place a fence around the dimensions and key in: FENCE THAW, this will bring the dimensions back.
Thanks for your help..
