3.3KV synchronous motor
Hi people
I am looking for a supplier to give me information on a 3.3KV Synchronous motor which will be used to drive a Mill. Our exsisting one is over 60 years old and am looking to upgrade, preferbly with solid state starter technologly. Do not wish to use liquid resistance starters.
If any one can help out with the direction i could look please let me know
Greg
RE: 3.3KV synchronous motor
Just out of curiosity, why is an induction motor ruled out?
Streeta
Try this lynk .They should be able to help you
www.direct-industry.net/nfk/en/synchronous-motors.html
 On UKPete's question.
I believe the reason why we choose Sync motors instaid of Async drives, has to do with power factor correction.
In One Copper Mine that I am familiar with,we had 4 rod mills, 5000 hp each and 4 ball mills also 5000 hp.This combined load of 40000 hp was all in sync motors
 If you had an equivalent HPower in Induction motors, your
power factor would be extremely low.The cost of Power Factor correction for such large inductive loads would probably exceed the cost of the Syncronous motors.
I would like to learn about another possible reason if anybody knows one.
Thank you
GusD
Streeta
What is the power rating of the motor ?
Today, it may be better to use a standard induction motor + power factor correction capacitors.
If you are interested in MV soft starter, you can look in www.solcon.co.il
Yoram
Suggestion: Visit
http://www.thomasregister.com
and type Motors: Synchronous under Product or Service, which will return 109 companies to approach to
ABB can supply both. Also Siemens. I am assuming that you are not in North America since you are looking for 3300V. Repost if I'm wrong and I'll give you resources in the US & Canada. BTW, it is always best to mention your general location when asking for resources.
One more thing to add for UKpete, shaft speed is usually an issue. Synch motors can be made to turn at lower speeds without loss of effeiciency, i.e under 600RPM.
By the way, going with an induction motor in place of a synchronous and adding capacitors is just asking for trouble. Stick with the synch.
Quando Omni Flunkus Moritati
