Stator failure 6kV synchronous motor
Recently we have had a ground fault in the stator of a 11MW synchronous motor. A condition measurement(PI,PD, surge) 1 month before the event showed no indication of deterioration. The motor is directly powered by a VF drive.Cable length is too short for voltage doubling. Measured rise times do not exceed 5000V/us. Motor is only 3 years in operation and winding temperatures never exceeded more than about 50 degrees C. The failure occured while in "idle" mode, taking about 1% load. So far we have no indication of a cause.
RE: Stator failure 6kV synchronous motor
Have you had a chance to give a visual inspection of the stator to rule out the obvious causes such as contamination/moisture?
If you do not look for electrical faults in your VA analysis it may be helpful to have someone review your VA readings for anything unusual, but not bearing related.
Please keep us updated if you discover anything.
A few questions....
1. How far away from the neutral point did the fault occur?
2. A machine this size should be equipped with a 'Rotating Machine Surge Protection package'. Is this one protected? If yes, is the package located at the motor or far from it?
3. You said that the machine was in idle mode, do you normally shut it down from idle mode? If yes, what was the power factor at that time? the current? and what type of breaker is it that opens the entire circuit? Is there a breaker between the drive and the motor?
GH
What kind of load move this motor?
Do you know if not have problems with the peaks of the drive?
Any problems with the drive before the failure?
Alfredo Corona
Mexico
Since you say motor was tested (PI, surge) one month prior, I assume this was a maintenance outage. How long after machine restart did failure occur? Was some form of space heating used to keep the machine dry?
I would also go back and take another look at the surge test results to make sure there was no slight indication of failure detected/caused during that potentially-destructive test.
Stator shorted to ground after some tests were performed shortly before the failure.
You mention that PI,PD and Surge tests were performed ,but you don't mention at what voltage levels were these tests
performed at.
The PI (polarization Index) test is usually performed at much lower levels than the operating voltages.It measures the dialectric value of the insulation but does not stress motor to its operating levels.The same could be true for the surge tests.As for the PD (partial discharge) test,it too, may not stress the insulation to its operating levels.
Regardless of what tests one performs ,unless you apply
opearting voltages that stress windings (such as in HI -Pot tests)Phase to phase or phase to ground insulation cannot be guaranteed (99%at least).
Understanding that TEST voltage levels for used motors would be slightly lower than FOR new motors (2Xnominal Voltage +1000 )is the rule for new motors.
The other suggestions regarding possible low ins.values due to Hi-humidity or others should not be discounted without further investigation.
GusD
-Motor is part of a steel rolling facility with a load cycle of say 3 mins full load, 6 mins idle mode(15% speed, 5% current, power factor ??)It is a 12 pole motor running at 170 rpm nominal speed.
-Inspection after failure showed no moisture. Some contamination was found, analysed in 2 labs, no cause for failure. There were also no traces of corona, loose wedges or dust from vibration problems.
-We have crowds looking at the measuring results, maybe one lead to an early indication coming up.
-Fault occurred in 1st coil, 1st turn, from motor terminals.
-No surge protection package installed, measured rise time within expectation from drive side and motor design spec, there is no breaker between motor and drive.
-We have regular bi-weekly shutdowns that we can use for condition measurements. Space heaters are in use. Motor had been in operation for a month, after the measurement before the fault occurred. We have an on-site motor maintenance team, which is experienced in large motors.
- We have had no problems with the motor/drive before the fault.
- Because of motor confuration - coils in parallel and in series, surge tests will give little information.
- Hi-potting will not be done as a maintenance test, other measurements are done at nominal voltage
Is there sign of turn or ground failure? If it was a turn insulation failure, there is normally a lot of copper melting. Is the location of failure on end turn or slot?
You say there are difficulties with surge testing on this particular motor, but surge testing was conduted. Is it possible the failure/degradation begun during surge test but was not noticed at the time.
You say that the PD test was done on this motor. I think that this test was done in offline situation and it's results didn't show any problem.if this is true it must be recommended that offline PD test doesn't able to detect all of the insulation defects. because the failure was occurred at 1st coil of the motor winding, I think that if there is any void or tree channel in insulation it would be recognized ( if suitable PDA instrument ws used).therefore insulation delamination may be occurred in your motor's winding.
Insulation delamination occur when thermal cycling applied on groundwall insulation because of different thermal expansion coefficients between copper and insulation or even different layers of insulation.
In stable thermal condition, e.g. in trips periods, gaps which is made by delaminaton dissapeared or very decreased and therefore insuation resistance and dissipation factor were affected notsensible
Electricpete, We assume it started with a turn short in the slot, turning into a ground fault. We have found melted copper/iron over about 40 cm length in one slot, but no large holes were seen. The motor was operating at a low current. We did not have difficulties measuring, but interpreting the surge test. On a motor with many parallel and series circuits, the response on the surge pulse does not really tell you a lot.
Mirbaghri, We have been told that an online PD measurement for HV PWM machines is not available yet. If you know a manufacturer with a working system, I would be very interested. If the motor ran hot, thermal cycling would certainly be considered as a cause, but as it is running very cool, this seems unlikely. Insulation resistance and dissipation factor had not changed in the last measurement before failure.
The fact that it was a turn insulation failure at the first coil is consistent with this theory (as well as surges from other sources).
Assuming that you plan on rewinding the motor, during the teardown you may have opportunity to isolate the coils and hi-pot and/or surge test other coils to failure? That may give you a rough feeling for general strength of your ground and turn insulation (but of course may not detect problems localized to one coil).
Regarding mirbaghri's suggestion of thermal cycling.... it seems it may not limited to motors which run abnormally hot. Long length stators with a lot of up/down cycling may be susceptible.
Out of curiosity, how did you measure your surge environment. That seems like a challenging measurement to make. Did you characterize the peaks as well as the rise times?
Also I assume your guys are looking at the existing motor insulation system design. Clearly dedicated turn insulation would be required for this application (I have seen several large motors without dedicated turn insulation... just used the strand insulation as turn insulation).
Presumably the machine has passed many surge tests including high levels when new. But also isn't the theory that surges can degrade insulation over time. I have also heard that mylar tape insulation can degrade over time under voltage stress.
1. First turn is involved
2. Test have been performed recently
3. Turn to ground fault
4. Idle mode of operation implying moderate temperature, no interturn stresses due to high current, etc.
5. Light load conditions, implying higher voltages
6. The highest chance for the weakest insulation spot, i.e. the lowest insulation and surface resistances to ground
etc.
The more thorough analysis of the fault and consequent damages is needed.
More so than than high speed motors low speed motors suffer from high core loss. I have seen where in a case such as yours that the motor had been repared and not core loss tested and had iron loss. It may not look like much for the size of the core but the rating are much lower for slow speed motors. That siad, ask them to test the core and and see if there is a hot spot there. That speed in my experience calls for either the coil itself to be wraped every coil with nomex as phase paper. Pure nomex as slot cell. I test a motor in your instance "time frame" use a megger or P.I. tester for the general tests only surge test maybe once a month at most it really should not hurt it but not worth the chance. Really wish I could see it could give you a better diag. Could you email me a picture?
After long discussion, decision was made to replace whole stator and not rewind. So we eliminated the risk of finding damages to the iron package. When inspecting with a boroscope through the ventilation ducts, we did see some damage to the iron package, but could not quite assess the extend of the damage.
Electricpete, not quite sure what you mean with measuring the surge environment. Our approach is to take "fingerprint" measurements when the new motor arrives and then compare further measurements to this fingerprint. Only if a clear difference is noted will we start to analyse the cause for this difference. So far for these motors we did not find significcant differences. Surgetest was done 2 times after the fingerprint with about a year in between measurements.
Jbartos, we are certainly considering the spike as a possible cause, but cannot find any evidence for an external event that would be able to damage a well insulated motor and not the sensitive pc's/drives/I/O alongside it. I tend to disagree with your point 5 as the motor was running at low speed at the time of the fault, so the VFD would only have given it a 15%rms voltage. Yes we are planning a thorough root cause analysis, but still, the fault may have destroyed the evidence.
Induction, I am not sure how I gave an impression of a recurring fault, but this fault is the first and only we have had on these machines. If you post your email address here I can send you a picture, but that will not reveal much more then a simple description here: a 4 meter by 4 meter stator housing with a 2 meter inside diameter for the rotor. And on the insde of the stator a minute black spot of 10 cm wide, 40 cm long.
Oh yes, I have to come back on what I said on space heaters. We do have them, in the end bells, but do not use them. This is because there is a water to air cooler on top of the motor that is always on, with water that is always 27 degrees C. So there is a constant flow of warm air circulating through the airducts, keeping the motor nice and dry at 27 C (well above dewpoint).
By surge environment I was not referring to the motor surge withstand, but the power system surges... specifically your statement "Measured rise times do not exceed 5000V/us" How was this measured? (what instrument, what location?).
///Spikes do materialize alone or with surges in form of a surge peak.\\\
///Agree. I meant the high input voltage to VFD. Many power electronic devices have input voltage range/window.\\\
///Yes, however, certain traces of the fault remain, e.g. location, magnitude of the fault, some conditions under which developed, etc.\\\
Surge environment was a 200MHz scope with a fast HV probe measuring right at the motor terminals during rolling on the twin motor (different VFD)of the failed one. Later this was repeated on the VFD that drives the failed motor, when we had a replacement in place.
Jbartos: on your following point:///Agree. I meant the high input voltage to VFD. Many power electronic devices have input voltage range/window.\\\We have designed the supply side to be within range for both full load and no load conditions and we may have like a 10% increase on no load. I agree that this will have an effect in a worst case scenario.
I do appreciate everyone's input. We have 5 more motors like this and all are very critical for production. So we would love to come to a conclusive root cause.
Henkv
After you received a lot of good info,I don't know if you have any better idea as to the cause of failure.
You still have another 5 motors being used .If the problem is a system problem (VFDs)rather than a motor pronblem, it could just as easy happened on any of the other motors.
When one hears of 1st coil,1st turn fault automaticaly we assume a Voltage spike from inverter use.
I just like to mention something that is a characteristic of most windings (Form or Random).When coils enter or leave slots, they can be stressed with a downword pressure that weakens the Millar slot insulation.At times this insulation is actually cracked under the coils.It is true that it happens much more on Random windings than on formed coil.I have seen formed coil windings that have shown the tell tale marks.When this happens,motors may pass most tests,with age,this weak spot will be the weak link.This may not be the case, and it is easy to look for this condition.
If your rootcause does not show a possible power problem,how do you plan to test the other motors to make sure they are sound ? Henkv, If you don't mind, give us an idea how do you plan to check the other drives.If you are going to test'em.
GusD
Gusd, we have inspected the places where the coils come out of the slot, but did not see any damage. The fault occurred some 40 cms from the side of the slot. If the VFD is ageing the insulation, we hope to get proof of that from the 1st coils of the other phases. If we don't find any cause .... we may have to get some more spares! We are doing some tests with a system from Delft university that may provide more insight from a PD test. When that proves to be helpful I'll let you know.
Henkv
Do you mean 40cm from the end of the slot? Inside the slot section or outside the slot section (in end-turn area)?
Just clarifying, (I thought you said before it was in the slot sectin?)
just to build on a comment made previously: many years ago we had two 300 HP Laurence-Scott wound rotor NS-type motors (3.3 kV 50 Hz stators) driving pumpsets at the bottom of a well. The motors were air-cooled and well-ventilated except the air was basically being recirculated within the well. Temperatures always remained well within acceptable but we experienced several consecutive motor failures, one very soon after a after complete re-wind. It was then we discovered the atmosphere was mildly corrosive, I can't remember with what, but the introduction of fresh air eliminated motor failures for many years after. The chemical in the air had been attacking the insulation.
Startup is current limited and no load, so we don't see these high forces in the slot or outside the slot.
On inspection after the failure, we checked for both moisture and corrosion, but none was found.
Your aanswer to Henkv thread, brought back some bad memories of mistery motor burnouts.We had a Fire Water pumping station with 3 -50 hp vertical pumps.This building was somewhat isolated from the main buildings in this Plant and just like clock work,we were loosing a stator every 3 months or so.These motor burnouts went on for some time on equipment that ran very rarely.One day,we happened to be in the building when the Fire Crew came in to test their Extinguishers(Dry Chemical)
That kind of gave us the clue.
They too use to test many Extinguishers at 3 months intervals,and we lost motors nearlly every 3 months.
After they stopped this practice inside the building the motor burnouts stopped as well.
GusD
Henkv
