How to design a spring that would work in all three direction ie x,y ,
Hello
I would like to know about any suspension system which can take loads in all three direction ie x y z with a maximum deflection of +or - 1.5 inch
regards
caaemaniac
regards
caaemaniac
RE: How to design a spring that would work in all three direction ie x,y ,
Sincerely
Shieldmaker
I had thought about the fire stone air spring
since somebody else had done it
i wanted something new
could you be more elaborate in telling me how how co centeric spring works with rubber
regards
caemaniac
at least two sheels, sparated by an arrangement (icosahedron, for example) of rubber pads.
It works in similar way that a rubber springs composed by a metalic plain washer joined with a rubber washer, then joined with a metalic washer and then again rubber washer....This arrangement in order to get more linear-like curve force-versus-deformation
I hope this can help you
Sincerely
Shieldmaker
i have problems visualizing it
if you dont mind could you please give me a schematic diagrame
my email id is rupi12@rediffmail.com
i have designed a system i would like to send it as a attachemnt
regards
casemaniac
If you put 6 stiff springs attached orthogonally and suspend the whole thing in a box, that will satisfy your problem statement.
TTFN
