70 % NaOH storage material
Dear colleagues,
Does anybody know's what material I can use for storage of 70 % solution of NaOH at room temperature ?
Thank you.
Regards ,
Chemical Engineer
Kukoljac Milos.
Thank you.
Regards ,
Chemical Engineer
Kukoljac Milos.
RE: 70 % NaOH storage material
Try the web link of Nickel development Institute(NIDI). They have large information on caustic application.
SS316 would be the most suitable material for 70% NaOH at ambient temperature. For higher temperatures, Ni is the recommended material.
Temperature will determine your storage material......what temperature do you need to store the caustic without it freezing ?
Try these links:
www.hghouston.com/x/20.html
www.corrosionsource.com/technicallibrary/nidi/literature
www.corrosionsource.com/technicallibrary/nidi/literature/literature9.htm
Nickel (alloy 200) is very, very expensive and only useful in applications where high concentrations of caustic (>75%) are at high tempertatures ( >212F)
Good luck.....
Let us know what your final decision is...
MJC
Regards.
