Beam support for cracked cmu basement walls
I need a detail for anchoring the top of a w-section against a cmu basement wall that has buldged and cracked. The floor slab has been sealed for radon, so I plan to use epoxy anchors to connect an angle to the floor to hold the bottom of the beam in place. I need details for the top of the beam for floor joist (2x12) parallel and perpendicular to the wall.
RE: Beam support for cracked cmu basement walls
I don't have the Hilti catalogue here... but they may have connection strengths on their website...
