yield line theory - column base plates
Can I get some literature on analyzing steel base plates with yield line theory.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: yield line theory - column base plates
You can try a regular yield line approach with the sagging lines following the web and flanges and 'fiddle' with the hogging ones...
The plastic section modulus for a plate (rectangular section) is 1.5 times the elastic section modulus and there is a significant strength gain (no stabillity issue for plates in this application, the ultimate in compact sections).
http://www.steel.org.au/members/pdfdocs/sc_v36n2_web.pdf
