Bridge R/C deck overhang, shear check?
I am analyzing a R/C slab for a bridge deck overhang. The overhang will be fixed on one end (prestressed girder beam flange interface) and free on the other. The free end is supporting a safety shape rail (considered continuous rail). The top steel from the bridge slab runs transverse, and is the main tension reinforcement for the overhang. The Live load is an HS25 type truck. I am using AASHTO spec. The dimension for the overhang is 3.5ft (centerline of exterior girder TY IV to edge of slab). There is only standard dead load from slab wt. & overlay. Will be using Allowable stress design. I am familar with flexure checks due to rail (impact load) and Wheel load. But not any shear checks? AASHTO does not specify shear for a cantilever slab (AASHTO 3.24.5). distribution width for truck load? Why? Any thoughts?
Inappropriate post?
If so, Red Flag it!
Check out the FAQ
Inappropriate post?
If so, Red Flag it!
Check out the FAQ
RE: Bridge R/C deck overhang, shear check?
In other words... Don't worry about shear for the design of the slab.
MikeD
Good Luck
MikeD
