Triangular Duct Dimensions Equivalence to Round or Rect Ducts
I am trying to size a traingular shaped return air duct and haven't found a table equating it's dimensions to those of a rectangular or round duct for air flow equivalence and inches of water.  Does anyone have any guidelines?
Thanks!
P.S.  I am doing this to shove the return air into the side of an attic where the rafters meet the attic floor.
RE: Triangular Duct Dimensions Equivalence to Round or Rect Ducts
For an equivalent circular duct having equal VELOCITY and PRESSURE DROP, calculate the hydraulic mean diameter dh thus:
dh = 4 * (cross sectional area / wetted perimeter)
If, on the other hand, you want to find an equivalent circular duct having equal FLOW RATE and PRESSURE DROP, the formula is a little more complicated but it will be something like 10% greater diameter than that given by the above formula.
Brian
