script files
script files
script files
How do I save a script file after I make it
When I make one do i put the .scr name in the title of the drawing if so where do I save it to
I keep getting cant find file when I try to run the .scr file
RE: script files
Save it as file.SCR , it is a TXT file with other extension that shall be xxxx.scr.
Pardal
RE: script files
I make a file in word or excel and save as  *.txt. Then I  rename (W-Explorer) the file in *.scr. ->  execute the script in AC
Lothar
Win NT4.0 (SP6),
ACAD 2000i (SP2), ADT 3.0 (SP3),
ACAD 2002, ADT 3.3,
OCÈ 5200
RE: script files
Depending on the length and complexity of the script file, you can create a customized tool bar button to execute the script file (macro), or create the file in an ASCII editor and save it with a .scr extension and load it by typing script.
RE: script files
Yes -
To your 1st question.
(Do I save the file with an extension "*.SCR"?)
Anywhere you want -
To the next question
(Where do I save it?)
As for running it ....
Go to the pull down "TOOLS" > "RUN SCRIPT"
This should pull up a browser ....
Then just point to it .... highlight it ... and run it.
If it doesn't run ...
Are you somehow associating the script to a "BUTTON"?
Or What?
